Is this the correct setup? Non-Newtonian fluent Problem |
May 4, 2016, 02:57 |
Rep Power: 9 |
Problem: You have a thickened (non-Newtonian) fluid passing through a water bottle top, where you know the initial pressure is vacuum (0kpa) and the a lab results gives you a flow rate of say 0.000779kg/s and the static pressure drop was seen as 10kPa with laminar flow. (assuming model and mesh is done and fluent set up is only needed)
General:Pressure based, Absolute and steady Models: Only viscous (Laminar) Material: fluid is almost like water, copy water poperties and change viscosity to non-Newtonian power law and add parameters Cell Zone conditions: Change it to you non-Newtonian fluid Boundary conditions:Set operation conditions to 0pa Define inlet as Mass-flow-inlet at 0.000779kg/s Define Outlet and Outflow Define interior and walls Solution methods: Use Simple Solution controls: Change nothing Solution Initialization: Hybrid with 10 steps, initialize Run Calculation: run with 250 iterations and what for convergence Wala take results???? Is this correct or have I missed something |
May 9, 2016, 01:59 |
Rep Power: 9 |
Bump, Please help :/
May 18, 2016, 02:05 |
Rep Power: 9 |
Also like to add I am getting a shear rate of crazy amount from a range of 20-10,000 1/s
May 31, 2016, 12:07 |
Bhargav Bharathan
Rep Power: 10 |
Your set up looks fine. I suggest going to monitors and setting the residuals to atleast 1e-5 for better precision. As for the shear rate, where did you arrive at numbers as big as 20-10,000 1/s? I generally give small numbers of the order 0.01. -BB |
June 16, 2016, 21:16 |
Rep Power: 9 |
I meant strain rate... Sorry somehow I was must have misread it... but for my Wall Shear stress it is around 0 (possible very very small) to 43pa.. Btw thank you for the reply, what I am trying to find is Strain and Shear rate range to determine if the simulation is viable though I am not sure if I am using the right methods to do so.. I am just using Contours and using the range they give me.
August 31, 2016, 16:43 |
Yielded and unyielded region in viscoplastic flluid
Hey Everyone!
I'm unable to plot yielded and unyielded region for a flow of viscoplastic fluid in a square enclosure. Help me I'm stuck. Thanks |
Display Modes | |
Porous media setup issues in Fluent | Bernard Van | FLUENT | 29 | January 26, 2017 05:09 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 14:41 |
Setup Cell Error in Fluent on Workbench | tolu | FLUENT | 1 | September 12, 2013 14:28 |
[ICEM] [FLUENT] 2D Geometry problem when exporting to Fluent - Unwanted walls | MikeTichondrius | ANSYS Meshing & Geometry | 1 | February 9, 2011 14:31 |
problem about periodic boundary condition in Fluent | winnawinna | FLUENT | 0 | December 29, 2010 00:32 |
