UDF COMPIL FOR FLUENT
Old   June 4, 2006, 19:43
Default UDF COMPIL FOR FLUENT
Benzamia
hello evry body I have Fluent 6.12.16. I have installed Basic C compiler the probleme is for dynamic mesch when i use
define---user-define -fuction-interpreted they work for other udf (profile velocity) but not for motion gird he make me error :
Warning: incorrect cg motion UDF benzamia on zone 3 (assuming no motion)
can any one help me please it's very urgently for me
------------- programme-----------------------
#include "udf.h"
DEFINE_CG_MOTION(benzamia, dt, vel, omega, time, dtime) {
/* reset velocities */ NV_S (vel, =, 0.0); NV_S (omega, =, 0.0);
if (time<0.1)
vel[0] = 0;
else
/* set x-component of velocity */
vel[0] = 0.1; vel[1] = 0;
Old   June 5, 2006, 04:21
Default Re: UDF COMPIL FOR FLUENT
adriano
why don't compile that? regards
Old   June 5, 2006, 16:23
Benzamia
can you help me i want to make move my cylinder in the middle of the fluid when download udf for dynamic mesh zone, fluent make me a warning: Warning: incorrect cg motion UDF mouvement on zone 4 (assuming no motion) zone 4 is my cylinder
what means this warning
thanks
Old   June 8, 2006, 01:00
Fabrice
Hi Benzamia,
I got the same problem than you.In fact, with a DEFINE_CG_MOTION, you have to compile it and not interprete it (it doesn't work otherwise). Be sure than your C compiler works well otherwise you will get the same problem. I suggest you Microsoft Visual C++ 6.0 (the official version; the free version doesn't work for this). Your UDF is correct, you don't need to put vel[1]=0, it's done by NV_S(vel,=,0.0).
Furthermore, I use an UDF quite similar to yours for a dynamic mesh but the mesh isn't updated and after a few iterations, I've got this message:
Mesh Statistics: Min Volume =-6.89746e-002 Max Volume =5.99320e+004 Warning: negative cell volume detected! Error: Update dynamic mesh failed! Error Object: ()
whereas I specified a dynamic mesh!! Any idea??
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
