UDF error-help needed
Old   June 7, 2006, 12:31
Default UDF error-help needed
James
Hi All,
I am trying to run my UDF in batch mode using fluent parallel. I am using two processors and each time i submit a job, i am getting the following error message:
Opening library "libudf"... Primitive Error at Node 0: open_udf_library: No such file or directory error: executing task of job 787527 failed: error: executing task of job 787527 failed: error: executing task of job 787527 failed: error: executing task of job 787527 failed:
For one raason or the other, it cannot locate my shared library. But i do the compiling of the UDF on a local machine (even though i am logged on the cluster from the local machine), the compilation and uploading seems to work.
Any help will be appreciated.
James
Help needed on UDF for modification of default syamlal o' brien drag law caai9 Fluent UDF and Scheme Programming 9 August 20, 2014 08:52
Help needed with UDF writing (CREATIVITY WELCOME!) ximik Fluent UDF and Scheme Programming 0 May 13, 2011 12:13
Help needed with UDF writing (CREATIVITY WELCOME!) ximik Main CFD Forum 0 May 13, 2011 12:11
Parse error in UDF, URGENT HELP NEEDED!!! Boris Kloser FLUENT 2 December 12, 2009 03:16
Help with UDF for BC needed. Albert FLUENT 1 January 7, 2004 13:32
