-   -   UDF error-help needed (http://www.cfd-online.com/Forums/fluent/41299-udf-error-help-needed.html)
James June 7, 2006 12:31
Hi All,
I am trying to run my UDF in batch mode using fluent parallel. I am using two processors and each time i submit a job, i am getting the following error message:
Opening library "libudf"... Primitive Error at Node 0: open_udf_library: No such file or directory error: executing task of job 787527 failed: error: executing task of job 787527 failed: error: executing task of job 787527 failed: error: executing task of job 787527 failed:
For one raason or the other, it cannot locate my shared library. But i do the compiling of the UDF on a local machine (even though i am logged on the cluster from the local machine), the compilation and uploading seems to work.
Any help will be appreciated.
James
