reverse flow
Old   June 8, 2006, 02:09
Default reverse flow
kumar
i am getting reverse flow at the outlet boundary.what should i do?does it affect the result?
Old   June 8, 2006, 02:22
Default Re: reverse flow
Fabrice
if your bound is not too close to what you study, it will not affect the results. So enlarge your domain of study or change of boundary type if possible.
Old   June 8, 2006, 05:28
naser
if your outlet BC is pressure-outlet note that you do not need to set a BC since it's asked for backflow pressure i.e. a flow inter from the outlet which is the source of reverse flow.
Old   June 8, 2006, 06:05
kumar
Right!my outlet BC is pressure-outlet.u mean there is no need of setting outlet BC.
Old   June 8, 2006, 07:09
naser
exactly
Reverse Flow Bharati FLUENT 0 September 14, 2010 01:09
Flow simulation in reverse drum mixer Patel Chirag CFX 0 July 19, 2010 15:05
reverse flow alikami FLUENT 1 June 2, 2010 04:19
Reverse flow in the VOF model yan FLUENT 1 May 26, 2005 09:14
reverse flow Giovanni FLUENT 11 October 15, 2001 03:01
