Home > Forums > FLUENT
meshquality: urgent
Old   June 9, 2006, 02:46
Default meshquality: urgent
Madhukar Rapaka
hi thanks for the resposes. I have checked the edge ratio, equi skew angle, equiskew size to ensure the mesh qulity. the edge ratio is perfect, imean ranging from 1 to 3, equisize angle is also seems to be ok(ranging from0.1 to 0.7 and very less elements has between 0.8 to 0.9), but the equisize skew for 34 elements in the mesh is greater than 0.97. can u please tell me whether the mesh is ok or not
thanks in advance
Old   June 9, 2006, 03:17
Default Re: meshquality: urgent
Gernot
1.) What problem do you have?
If itīs just the calculation of a temperatureprofile in a solid then I think itīll work.
If you have a flow I would say the mesh quality is to bad.
What to do? Hard to say without seeing the geometry and the mesh you have
Old   June 9, 2006, 03:36
Madhukar Rapaka
hi Gernot,
sorry for not explining clearly abt my problem
actually i'm simulating a flow thru a cylindrical reactor(this cylinder contains 6 more cylindrical uv-tubes parallel to the flow, ihave defined these tubes as walls; and the cylinderical tube also contains 3 baffle plates with small holes place perpendicular to the flow)
if u can give ur mail id i wll send the geometry to u.
thanks in advance
Old   June 9, 2006, 03:46
Gernot
I donīt want to post my adress here, but you can send me your mailadress to :
gernotlukesch@sms.at
Iīll contact you than.
Old   June 9, 2006, 03:56
Madhukar Rapaka
Hi Gernot
i didn't asked for ur mail address anyway, i asked for ur e-mail id only.
i wll send my file to ur mail id
Thanks
Thread Tools
Trackbacks are On
Urgent - Polyflow - particle tracking visualization -Urgent shafaatht ANSYS 0 October 13, 2010 04:56
Urgent, Urgent, a UDF problem, PLEASE HELP!!! Max FLUENT 1 September 24, 2010 20:30
Urgent! UDF error "implicit declaration of function" ivanbuz Fluent UDF and Scheme Programming 3 June 18, 2010 05:46
Urgent...urgent...plss!!! astronome FLUENT 0 October 16, 2009 07:17
tmerge urgent urgent jessica FLUENT 4 July 15, 2006 13:37
