Home > Forums > FLUENT
how to eliminate wall shadow
Old   June 13, 2006, 13:24
Default how to eliminate wall shadow
mohmed
i want to give me how to eliminate wall shadow , please give me the procedure step by step. best regards
Old   June 14, 2006, 01:34
Default Re: how to eliminate wall shadow
Gernot
Whats your problem with it? If you have an interface between liquid and solid I donīt think you can eliminate the shadow wall. If you have a shadow wall in your liquid and you want to eliminate it :
define / boundary condition
click on the shadow wall and change type to interior
Old   June 14, 2006, 04:46
mohmed
i have split rectangle with submerged cylindre , then i have got two cylindres, my probleme is situated in the wall of the submerged cylindre , fluent create wall shadow and wall in the submerged cylindre, how to eliminate wall shadow. best regards
Old   June 14, 2006, 04:58
Gernot
Iīm not sure about your problem. The wall - shadow-wall is it between your cylinders (crossection) or on the shell.
Old   June 14, 2006, 05:42
mohmed
the wall shadow is created between the submerged cylindre and water(rectangle) , here you have a reactor and cylindre go into a reactor then i have splited reactor with cylindre then you have two cylindres : one submerged and the other is situated at the top of reactor ; i have a probleme with wall shadow in a wall of submerged cylindre. best regards
Old   June 14, 2006, 06:10
Gernot
is the submerged zylinder and the rest of reactor the same material ( water? ) or is on solid and the other liquid?
Old   June 14, 2006, 06:23
mohmed
the submerged cylindre and reactor are solid then the other is water
Old   June 14, 2006, 06:41
Gernot
Either the wall shadow-wall is between the solid and the water. Then I donīt think you can change it. Because also itīs just one wall fluent makes an interface solid and an interface fluid out of it. If the wall shadow-wall is between the solids then you can change it to interior in the define / boundary condition panel.
Old   June 14, 2006, 07:36
mohmed
thank you
Thread Tools
Trackbacks are On
Very technical question about solving wall boundary layer ... jlb001 FLUENT 6 December 27, 2014 06:56
Patches for OpenFOAM 1.7 on MacOS X gschaider OpenFOAM Installation on Windows, Mac and other Unsupported Platforms 101 September 21, 2011 05:37
WALL and WALL shadow duaiduaihu FLUENT 5 May 3, 2009 09:44
Gradient over interior (shadow) wall D Krijgsman FLUENT 0 August 21, 2008 00:44
Fluent Not creating shadow wall Celine Garnier FLUENT 1 September 10, 2007 13:02
