How to Set Up Pressure and Mass at a Fluid Zone???
Old   June 14, 2006, 06:37
Default How to Set Up Pressure and Mass at a Fluid Zone???
Carlos V.
Hi Everybody
I need to set up a constant pressure of 10 bar and 2 Kg of hydrogen in a fluid zone, can anyone tell me how to do that?!I've tried to "patch" these zones but the "patch" menu doensn't let me do the mass "patching". I'me trying to simulate a closed pressure vessel, where I know the temperature, the pressure and mass of the gas, can anyone tell me the way I should do this?! Really need help on this one! Thanks!
Old   June 14, 2006, 07:18
Default Re: How to Set Up Pressure and Mass at a Fluid Zon
Gernot
you can change the operating pressure to that one you need. define / operating conditions
Old   June 14, 2006, 07:26
Carlos V.
Hi Gernot
Before anything I want to thank you for your response! I've already done that, my problem is that I want to simulate closed a pressure vessel, so I have no inlets and no outlets. I tried to make a UDF defining a mass source, however I'm not getting any results with that!I've already changed the operating pressure to the one I need, but I don't know how to define the mass of fluid inside the domain that I need. Can you help me on that?
Thank you once again!
Old   June 14, 2006, 07:35
Gernot
If you have a compressible fluid ( gas ) then mass of your gas is defined over pressure volume and density.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
How to apply negtive pressure to outlet bioman66 CFX 5 June 3, 2006 01:40
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
