June 18, 2006, 11:38 |
combustion pressure???
Hi Please how to impose combustion pressure in fluent? is it the operating pressure ? or should I impose it in the inlet boundary conditions ??
thanks for the help |
June 19, 2006, 00:26 |
Re: combustion pressure???
If you say that it is "high pressure combustion" then your operating pressure should be high. An inlet pressure generally is more relevant as a driving pressure (say compressor-line loss if you know). Which one of the two do you have depending upon that your input boxes will change!
Swarup. |
June 19, 2006, 04:45 |
Hi Swarup
I am simulating H2/O2 combustion under 10 bars combustion pressure. 1- when using presumed pdf, should I use 10 bars=10^6 Pa in the operating pressure for prepdf ?, or Should I use the 10 bars under fluent ? or simply, calculate the velocity injection of H2 and O2 ( according to 10 bars) and use velocity inlet BC, and keep 101000 in the operating pressure of fluent ? Thanks for the help. |
Maintaining Static Pressure at Fluid Flow Inlet | cdevalve | FLUENT | 3 | January 14, 2012 00:11 |
Oil combustion | brajh11 | CFX | 0 | March 8, 2011 16:55 |
Setup/monitor points of pressure and force coefficients | siw | CFX | 3 | October 22, 2010 06:07 |
Help ASAP! pressure inlet & outlet | engahmed | FLUENT | 0 | June 13, 2010 15:33 |
combustion -pressure ? | abel | FLUENT | 4 | February 5, 2006 14:21 |
