combustion pressure???
Old   June 18, 2006, 11:38
Default combustion pressure???
abel
Hi Please how to impose combustion pressure in fluent? is it the operating pressure ? or should I impose it in the inlet boundary conditions ??
thanks for the help
Old   June 19, 2006, 00:26
Default Re: combustion pressure???
Swarup
If you say that it is "high pressure combustion" then your operating pressure should be high. An inlet pressure generally is more relevant as a driving pressure (say compressor-line loss if you know). Which one of the two do you have depending upon that your input boxes will change!
Swarup.
Old   June 19, 2006, 04:45
abel
Hi Swarup
I am simulating H2/O2 combustion under 10 bars combustion pressure.
1- when using presumed pdf, should I use 10 bars=10^6 Pa in the operating pressure for prepdf ?, or Should I use the 10 bars under fluent ? or simply, calculate the velocity injection of H2 and O2 ( according to 10 bars) and use velocity inlet BC, and keep 101000 in the operating pressure of fluent ?
Thanks for the help.
Maintaining Static Pressure at Fluid Flow Inlet cdevalve FLUENT 3 January 14, 2012 00:11
Oil combustion brajh11 CFX 0 March 8, 2011 16:55
Setup/monitor points of pressure and force coefficients siw CFX 3 October 22, 2010 06:07
Help ASAP! pressure inlet & outlet engahmed FLUENT 0 June 13, 2010 15:33
combustion -pressure ? abel FLUENT 4 February 5, 2006 14:21
