Fuse or merge
Old   June 24, 2006, 09:31
Default Fuse or merge
Ligr
Hello friends.Please help!
My issue is not very dificult I bilieve but I have some truble solving it out. So: I have a simple model.A pipe with an object witch does not tuches the pipe wall.I want to model a pressure inlet and a velocity outlet.My results are concentrate on the flow around the part and after the cavitation. My problem is that fluent does not ''see'' the object and solves only the pipe.I have seen some options sutch ''merge volumes'' ''fuse volumes'' but I dont know what to do.
Thanks from now / Best regards from Greece!
Old   June 24, 2006, 23:47
Default Re: Fuse or merge
F.A.
How did you created the mesh? In Gambit? Make sure that you subtract the inner geometry from the surrounding pipe so that fluent recognizes this as a wall inside.
merge zones Domi FLUENT 2 May 3, 2019 13:15
[ICEM] Merge mesh - non manifold vertices BrolY ANSYS Meshing & Geometry 4 October 30, 2010 22:07
assemble the mesh feixiangniao ANSYS Meshing & Geometry 2 March 20, 2010 02:39
Fuse simulation canopy Main CFD Forum 0 February 11, 2009 03:24
about merge mesh lian Main CFD Forum 3 February 29, 2008 10:47
