-   -   Combustion problem (http://www.cfd-online.com/Forums/fluent/41501-combustion-problem.html)
Rams June 24, 2006 04:31
Combustion problem
I have solved a combustion problem using mixture fraction Pdf model without checking for damkohler number,...
Am having a problem with the solution,.. am getting negative pressures at nozzle throats,... is this bcoz i may have selected wrong model,..
i have even tried to solve the same problem with species transport model but i failed even to start the solution with that model,.....
what should i do,.. to get correct result,...
