non-positive volume after initializing
Old   June 26, 2006, 09:42
Default non-positive volume after initializing
draussen
Hello, I'm a new fluent user. I try to compute multiphase flow with the eulerian model. But after the initialisation i get a warning about non-positive volumes. I don't know what the problem is. Could anyone suggest what the failure is? I think it has nothing to do with my mesh. Because I got a solution with one phase model. And when I read the case file and check the mesh, there is also no problem. I would be very thankfull about any answers!!!
Old   June 26, 2006, 09:58
Default Re: non-positive volume after initializing
draussen
Hello, the problem has something to to with the axissymetric option in the solver panel. I think there is a problem with nodes below the x-axis.
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
