Fluent default settings
Old   June 26, 2006, 02:24
Default Fluent default settings
PAD
Hi all,
Is it possible to define the default settings for Fluent when it opens? It can be done with the positions of the different windows which are saved in the .cxlayout file, but I cannot find a file specifying e.g. the default Grid Display.
Current default "Grid Display" Options | Edges Edge Type | All
Wanted as default "Grid Display" Options | Edges + Faces Edte Type | Feature
Should I specify my desired default settings using a journal file?
Regards, Per
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
Fan settings in fluent fluent_beginner FLUENT 7 February 23, 2012 22:13
Discretization settings Foam vs. Fluent wuppdupp OpenFOAM Pre-Processing 6 July 25, 2009 02:35
Fluent connection with simulink by TCP/IP Tanktruck Fluent UDF and Scheme Programming 1 June 28, 2009 12:56
Default settings for 3D boundary layer-Gambit 2.2 Ramine FLUENT 1 July 31, 2006 12:36
