June 23, 2006, 10:23 |
two phase porous region
Is it possible to model two phase flow in porous media using fluent .I am simulating boiling in porous region? what problems can one face?
June 23, 2006, 11:36 |
Re: two phase porous region
You will need to write your own UDF to handle this, the basic model is single-phase only.
June 23, 2006, 12:31 |
thanks for the reply .Can u be more specific .what i have to include in my udf to modify the porous model?
June 26, 2006, 11:14 |
The built-in porous model is just a fluid region with an extra momentum sink term. You would need to write a UDF that looks at the two phases and computes an appropriate sink term. I've never done this, so I can't help you with the actual writing.
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 04:04 |
How do you set up a porous region | charltonjames | STAR-CCM+ | 13 | August 13, 2011 18:29 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 04:38 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
velocity at porous region | CHUBBY | FLUENT | 3 | May 15, 2001 23:37 |
