boundary layer mesh quality
Old   June 27, 2006, 11:58
Default boundary layer mesh quality
Francesco
Hello everyone,
I am trying to mesh a turbine blade using Gambit 2.2.30 and I am facing some problems with the boundary layers. I have defined boundary layers on the suction and pressure sides of the blade. Close to the trailing edge (where the surface has a very high curvature) I am getting very skewed elements. The reason for this seems to be that the growth direction of the boundary layer in this region of high curvature is not perpendicular to the surface. Is there a way to improve this, for example tweaking the boundary layer defaults? I have tried to modify some values of the default parameters, but I wasn't too sure about what I was really doing, considering the fact that on the manual only a couple of (not very clear) lines of explanation are given for each of the commands.
Thank you Francesco
[ANSYS Meshing] Creating Hex Boundary Layer Mesh and Unstructured everywhere else NLao ANSYS Meshing & Geometry 1 March 15, 2011 06:35
Not able to mesh a helix with boundary layer using gambit rohitjvbibin FLUENT 1 March 7, 2011 04:40
Not able to mesh a helix with boundary layer using gambit rohitjvbibin Main CFD Forum 0 March 5, 2011 11:28
How to make boundary layer mesh moving with wall wayne FLUENT 3 June 11, 2008 23:23
