June 27, 2006, 15:38 |
axisymmetric annulus modelling
hi, I am comfused how to model annulus flow, using axis symmetry, i am not able to decide which is the correct way to model
I am modeling in gambit pls help shashikant |
June 27, 2006, 18:11 |
Re: axisymmetric annulus modelling
Model a cross section of your annular geometry in the X-Y plane, where the axis of rotation of your annular geometry occurs at y=0 (the X-Axis).
Hope this helps, Jason |
June 27, 2006, 18:32 |
the c/s is a rectangular of say 5mm X 1000mm size and IF my inner dia is 10 mm this rectangle will be at 5 mm distance from x axis, NOW there is no edge at Y=0 to be called as axis
so i creadt a real edge at y=0, and label it axis now if I expoet the mesh i get the following error WARN: Boundary Entity axis.8 does not contain valid entity an is not written IS THIS method of modelling CORRECT shashikant |
June 28, 2006, 08:53 |
No. You don't need to create an edge to represent an axis in annular flows. Fluent already knows the X-Axis is your axis of rotation.
The Axis boundary condition is only used when the axis of rotation is in the fluid volume (i.e. the centerline of a pipe). Otherwise Fluent would treat the BC as a wall, which isn't realistic... you don't typically have an infinitely thin wire running down the centerline of a pipe. That's the only reason to use an Axis BC. For your geometry, just model the 5mmX1000mm rectangle that's 5mm from the X axis... that's it. When you run Fluent, make sure to change the solver to Axisymmetric. That's all there is to it. Hope this helps, and good luck Jason |
Display Modes | |
2d 1/2 axisymmetric annulus for POLYFLOW | j0hn04 | ANSYS Meshing & Geometry | 2 | March 7, 2020 13:55 |
Axisymmetric Modelling using 2D extrusion | Steve | CFX | 0 | November 12, 2008 13:05 |
Advice on multi-phase flow modelling | Martin | Main CFD Forum | 3 | October 14, 2008 06:16 |
Unsteady modelling technique? | Carlos | FLUENT | 0 | September 26, 2008 12:37 |
2-D Compressible Axisymmetric modelling | jehazneb | FLUENT | 0 | December 20, 2004 06:12 |
