June 30, 2006, 03:21 |
LES and total turbulent kinetic energy
hi!
i am doing a poiseuille flow using the LES turbulence model to get familiar with LES and Fluent. i'm using fluent 6.2.16. reynolds number based on the height between the plates is 5000. to check that the simulation is ok, one should monitor the total turbulent kinetic energy to see that it is stabilizing and the spectra of the turbulent energy should also be checked (if the spectra for high frequency turbulence is increasing, the mesh is too coarse). do anyone know how to extract the total turbulent energy and the turbulent spectra from the solution? also, the fluent user guide says that the subgrid turbulent kinetic enegy can be otained from the "turbulence" drop-down list in the postprosessing panels. it doesn't seem to be present. do anyone know the reason for this? regards, boerge |
September 8, 2012, 11:41 |
Khosrow Ebrahimi
Same problem as Boerge's. Any kind of help is greatly appreciated.
energy spectra from LES simulations | kumar | OpenFOAM Post-Processing | 2 | February 23, 2016 12:25 |
How to view subgrid kinetic energy | Craig | FLUENT | 3 | September 8, 2012 11:34 |
spectrum: LES of a turbulent channel flow finally goes to turbulent | liu | OpenFOAM Running, Solving & CFD | 6 | November 1, 2011 01:00 |
LES of a turbulent channel flow stays laminar | liu | OpenFOAM Running, Solving & CFD | 2 | May 27, 2010 13:53 |
Why FVM for high-Re flows? | Zhong Lei | Main CFD Forum | 23 | May 14, 1999 13:22 |
