createing a circumferential line on a cylinder
Old   July 6, 2006, 00:45
Default createing a circumferential line on a cylinder
Ralf Schmidt
Hi!
I want to know, how it is possible, to create a circumferential line around a cylinder for postprocessing.
Any idea??
Ralf
Old   July 6, 2006, 02:36
Default Re: createing a circumferential line on a cylinder
clem
you can create an iso-surface of grid (isox, y or z)based on the surface of your cylinder. The intersection will create the line you want. I just don't know how it will draw xy-plot due to the loop.
clement
Old   July 6, 2006, 03:15
Ralf Schmidt
OK!! thanks, that is working great!!!
xy plot is with option "curve lenght" no problem!
Now, when I want a line, that has 1 mm distance to that circumferential line around that cylinder, how to do that?????
Any additional idea??
Ralf
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
