createing a circumferential line on a cylinder |
July 6, 2006, 00:45 |
Hi!
I want to know, how it is possible, to create a circumferential line around a cylinder for postprocessing. Any idea?? Ralf |
July 6, 2006, 02:36 |
Re: createing a circumferential line on a cylinder
you can create an iso-surface of grid (isox, y or z)based on the surface of your cylinder. The intersection will create the line you want. I just don't know how it will draw xy-plot due to the loop.
clement |
July 6, 2006, 03:15 |
OK!! thanks, that is working great!!!
xy plot is with option "curve lenght" no problem! Now, when I want a line, that has 1 mm distance to that circumferential line around that cylinder, how to do that????? Any additional idea?? Ralf |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 | flakid | OpenFOAM Installation | 16 | December 28, 2010 08:48 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 04:26 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
