Vibrating Wall
Hello all,
I have a nozzle that has an constant inlet velocity and a inner vibrating wall. For the vibrating wall I have used a UDF and assigned it in the momentum section of the boundary conditions. When analysing the moniter I assigned to the wall, it shows that the wall IS vibrating as I wish it to. The problem is this is not shown when I contour plot the nozzle, i am expecting to see both pressure change and velocity change caused by the wall vibrating back and forwards around the wall. I have used the vibrating udf for an inlet velocity boundary condition in a previous model and it worked fine, Any ideas..........? Thanks in advance, Leigh |
Re: Vibrating Wall
If vibrating surface type is WALL, FLUENT allows it to move in-plane only, that is drops velocity components normal to boundary. Also check length scale - do you resolve boundary layer?
Re: Vibrating Wall
Thanks for your reply.
In my model I only want the wall to vibrate normal to the boundary (ie left and right in a 2D plane), so I think that is ok. The scale of the model is correct, it is very small, ie the virbrating wall is of length around 17E-06m. Also what do you mean by resolving the boundary layer? Ive done alot of browsing the manual and think maybe I need a dynamic mesh to model the vibrating wall. Any further thoughts? |
Re: Vibrating Wall
Yes you need to use the dynamic mesh because Fluent cannot account for normal velocity in the wall bc (only tangential). Luca
Re: Vibrating Wall
Thanks for the reply, I have never used a dynamic mesh before. I have had a look through the manual and the tutorial but I am not clear in what I am supposed to do. My model is a simple nozzle that has a vibrating wall that is designed to nebulise the fluid. I would like to see if there is any cavitation around this wall. Any help or pointers on dynamic meshes?? Thanks, Leigh |
