how to active Temperature equation in FLUENT
Old   July 10, 2006, 21:49
Default how to active Temperature equation in FLUENT
james
when i importing a FLUENT 4 grid file into Fluent 6.0, i get the following message:Temperature equation is not active (conducting walls are treated as walls). so, how to active the temperature equation or how to exchange the wall cells into solid. pls help me. thank u!
Old   July 12, 2006, 00:51
Default Re: how to active Temperature equation in FLUENT
PIfou74
I thhink that in fluent4, you should change your conducting wall in live cell excepted for the boundary condition where the conducting wall is taken as a "normal" wall. Normally, if you do that, when you import your case in Fluent6, you should have two zones and a "shadow" wall between these two zone.
Good luck
Old   July 17, 2006, 09:05
james
Thanks for PIfou74, I'll try it. Best wish for you!
Old   July 17, 2006, 09:49
james
Dear PIfou74, thanks for your help again! the fluid cell is defined live cell first in my programme. when i change the conducting wall into live cell , FLuent can not distinguish the two types. and i can not define the physical properties of the conducting wall. THX for your help!
Old   July 17, 2006, 12:26
PIfou74
I think that now, in Fluent6, you should have two fluid zone? One for the "real" live and one for the zone corresponding to the conducting wall. You just have to change this second zone properties in order that it becomes solid.
If you have not the two zones this is not normal. In Fluent4, when you change the conducting wall cells to live you should define as wall the cells at the interface between the live and the conducting wall.
Good luck
Old   July 18, 2006, 02:01
james
oh, yeah, i see. Thanks my dear friend,PIfou74. Bless you!
Transport Equation for temperature variance ameya OpenFOAM Running, Solving & CFD 0 December 5, 2008 01:16
how solve a scalar equation with Fluent tomik FLUENT 0 January 5, 2006 06:38
HELP!:CFD modelling using FLUENT in swimming pool Tee Main CFD Forum 0 September 7, 2005 20:48
Can FLUENT solve our own defined equation Sebeci FLUENT 3 April 22, 2003 15:20
Granular temperature equation ap FLUENT 0 April 18, 2003 13:30
