Annular Flow Using VOF
Like Tree1Likes
  • 1 Post By TedBrogan
Old   November 9, 2010, 13:58
Default Annular Flow Using VOF
patty
TedBrogan is on a distinguished road
I'm running into difficulty getting any sort of annular flow simulation using VOF to work in FLUENT. It's usually divergence in AMG solver or other fatal errors. I can run the simulations using VOF from the tutorials, but none of those give much detail on setting up an annular flow. Any comments or help is much appreciated. Ideally, a working case file for an annular flow or something similar that I can build from would be great.
Thank you,
Ted
TedBrogan is offline   Reply With Quote
Old   March 7, 2011, 11:14
patty
For reference for others in the future, here are some self-discovered tips for this type of scenario.
Have two separate inlets, one with all gas flow and one with all liquid flow. I've been using either mass flow or pressure inlets for the liquid and pressure inlet for the gas. The outlet is a pressure outlet. PISO and SIMPLE solvers have worked well for my transient simulations. I believe PISO is better for transient and SIMPLE for compressible so compromise has to be made. For initial convergence problems, I've found it helpful to turn off the energy equation initially and use very small iterations per time step (5-10) until the solution is more stable. You can get around that for a given geometry down the road once you have a decent solution by using interpolation as a starting point.
Old   May 3, 2011, 17:56
Anf893 is on a distinguished road
hello
I'm trying to do a simulation of annular flow through a pipe, I'm pretty lost, can you help me?
Anf893 is offline   Reply With Quote
Old   May 10, 2011, 11:38
patty
I never actually did pipe flow. It was nozzle flow, and I was just trying to start with a problem I hoped more people would have experience with. The tips I listed in the previous post were everything I was able to learn. You might try to repeat someone else's simulation as a starting point. I think I looked at:
Han, H., Gabriel, K., "A Numerical Study of Entrainment Mechanism in Axisymmetric Annular Gas-Liquid Flow," Journal of Fluids Engineering, Vol. 129, March 2007.
Good luck!
Anf893 likes this.
Old   January 1, 2016, 04:31
Mihiran
Mihiran is on a distinguished road
Originally Posted by Anf893 View Post
hello
I also require a help on this. Did you find any solution for this??
Mihiran
Mihiran is offline   Reply With Quote
annular, vof
Annular Flow in Pipes metro OpenFOAM Running, Solving & CFD 0 August 11, 2010 03:34
Air-water flow (VoF). Need help :( Luke1984 FLUENT 6 October 19, 2009 09:59
Annular flow JWilliams CFX 0 April 16, 2008 11:12
VOF transfer - multiphase flow karthik Main CFD Forum 4 February 2, 2006 01:25
VOF problem postprocessing display 3D flow profile Saturn FLUENT 4 July 14, 2004 00:58
