June 29, 2006, 16:01 |
Torque calcuation
How can I calculate the torque of the impeller blade in a stirred tank reactor?
June 29, 2006, 23:17 |
Re: Torque calcuation
Report/Force Choose Moment and the axis-rotation (also the center of rotation) of your impeller
June 30, 2006, 08:56 |
Thanks 4 yr mail. Can u use this moment as a criterion for the stability of my model? If it does converge, do u know why?
July 3, 2006, 00:53 |
sure: if you monitor the torque on a piston and it doesn't remain stabil (oscillations) then it is possible that you have unsteady phenomen
July 3, 2006, 09:49 |
Hey Mary,
I have been trying to model rotating blades. Can youn tell me how you set up Fluent for the case of your impeller blades? |
July 6, 2006, 19:53 |
How do u mean? Have u modelled your tank? If so, u read yr case file into fluent. there are two methods: Multiple frame of reference or Sliding mesh. Check Fluent tutorial for this. does this help
July 11, 2006, 10:50 |
Actually my case is not of impeller blades, it is of rotating helicopter blades, so there is no tank, there is only a pressure far-field. Can you tell me how to set up the problem? I have tried to make the fluid rotate in a direction opposite to that of the blades and keep the walls stationary (in this rotating frame). But this does not give the correct solution. I have looked up the fluent tutorials, but since they only show 2D cases in them, they were not much of a help. I checked some previous posts on this forum too, but the problem is not resolved. Can you tell me step-by-step, how you set up the wall and fluid boundary conditions for the case? I am using a Spalart-Allmaras turbulence model, coupled implicit solver. Thanks in advance, this will be great help.
NY. |
Display Modes | |
Torque calculation of 2D VAWT Wind Turbine | Anonymized_JL1 | FLUENT | 14 | September 26, 2013 03:35 |
FloWorks torque bug? | PJC | FloEFD, FloWorks & FloTHERM | 0 | November 8, 2009 18:41 |
positive and negative torque forces | Wei-Haur Lam | CFX | 0 | March 19, 2008 07:45 |
Torque definition | Yali | CFX | 2 | January 7, 2008 03:13 |
about use macro to compute torque in TASCflow | lancy | CFX | 0 | June 10, 2003 06:19 |
