radial inflow turbine rotor periodicity problem |
July 11, 2006, 20:35 |
hi, i've modelled a flow passage of a radial inflow turbine consisting 15 blades.for modelling purpose i made use of the periodicity of the flow and modelled a single passage.however when i displayed the result by taking 0.5 constant grid spanwise location and displayed the 360 degrees view, the default number of repeats was 17 which is not consistent with my model.any suggestion of what am i doing wrong? i've already checked and rechecked my model in gambit.
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
Calculating lift force of a wind turbine blade problem | LittleBart | CFX | 4 | June 29, 2011 02:33 |
Convergence of Radial Turbine Simulation | Hugh | CFX | 10 | June 30, 2010 08:08 |
radial turbine flow analysis | ME | Siemens | 1 | August 16, 2007 03:06 |
radial turbine flow analysis | ME | FLUENT | 0 | July 2, 2007 09:18 |
