Compiling my UDF
Old   July 11, 2006, 15:25
Default Compiling my UDF
chris
Hello, everyone. Now I try to compile my UDF. But every time, it appear such words as follows: 'nmake' is not recognized as an internal or external command, operable program or batch file. 'nmake' is not recognized as an internal or external command, operable program or batch file.
Do anyone have such experience and explain it to me? Thanks in advance.
Old   July 11, 2006, 15:37
Default Re: Compiling my UDF
jasond
In order to compile UDF's you need a compiler installed on your system that Fluent can find (you're running Windows, right?). Assuming that you have a compiler, it sounds like Fluent is not finding it - that may mean that not everything that Fluent wants was installed or set up - so you'll probably want to check on the installation.
Old   July 11, 2006, 15:39
cadaei
this is a common problem which can be solved by installing Visual Studio C++ or similar software. search the forum for nmake or contact FLUENT
Old   July 11, 2006, 15:41
chris
Thanks very much.
Old   July 12, 2006, 03:54
PAD
You can actually download MS Visual C++ Express from Microsofts web-site for free. This compiler works with Fluent - just remember to set all the system environment variables manually as these are only set temporarily using the C++ command prompt.
Old   July 12, 2006, 08:49
Vidya
You may want to talk to your system administrator about this. I faced a similar problem and the system administrator reinstalled the set up. Then everything was fine.
compiling udf at window Nt(64BIT) noa FLUENT 3 July 29, 2014 23:01
Compiling UDF on a cluster Adya FLUENT 1 December 14, 2009 11:30
UDF compiling problem in Flient 6.3 jeevan kumar FLUENT 2 February 25, 2009 00:43
udf compiling problem akr FLUENT 3 August 22, 2007 07:14
On Compiling a UDF David Chabot FLUENT 5 May 20, 2005 09:13
