-   FLUENT (
-   -   Tecplot with fluent (
Rafael July 12, 2006 08:54
Tecplot with fluent
Hello I imported .cas and .dat with tecplot fluent loader and iīd like to draw the contours of the Tangential velocity, but i donīt have the tangential velocity in contour details--> Var Does anybody know how to sort out the problems? Thanks Rafael
cip July 19, 2006 15:08
Re: Tecplot with fluent
in alter data equation
an there you have to specify your tangential velocity formula
shshiva17 August 25, 2009 07:15
hi frens
hey dudes,,,,
this is siva,,,,,,,
i donno tecplot,,if u hav any tutorials plz send me,,,,,am working on combustion field,,,,,,
plz send me if u hav any tutorials regarding tecplot,,,,,,,,
my email is
khairy February 21, 2010 14:34
plot tangential velocity in Tecplot by export data from Fluent
In my opinion the best way to do that is to export a tecplot data file from fluent directly as follow
from file menu select export then select tecplot
from the most right panel select the variables you want to plot say tangential velocity axial velocity ...
and from the surface panel select the surfaces say y0
(or any surface you already have, multiple selection is possible, every surface will be a zone in tecplot, if you did not select any surface the whole domain will be exported)
then press export
the generated file will be readable in tecplot
as follow, file ==> load data file ==> tecplot dat file
if you select some surfaces select 2D (or xy if you exported lines from fluent) while if you did not select 3D
also you can make slices to plot at certain plane or lines inside Tecplot
i hope these useful,
for more details check the Fluent and Tecplot manuals.
dynamicdom February 25, 2010 11:47
my Problem is to get graphics of cas. and dat. files in my powerpoint presentation. How can I do that?
Thanks in advance.
Best regards,
Shamoon Jamshed October 28, 2010 14:51
Go to file export here by default is WMF select bmp, jpeg or Tiff whatever you want and there you go!!!!!!!
saharesobh August 23, 2012 11:31
Actually I am working with Ansys Fluent and I am going to make plane in templet. I read what you guys wrote but I have problem with that. I went to file menu then sleeted EXPORT. But in export I could not find tecplot. The tecplot is in import. So would please give me some advice. The other question is that when I am using the other way to transport my model to tecplot, just the model got transported. I mean I could not see the velocity profile in my model ( because I am going to see the velocity profile in different positions (by making plane in the model). Would you please help me.
