July 12, 2006, 08:54 |
Tecplot with fluent
Hello I imported .cas and .dat with tecplot fluent loader and iīd like to draw the contours of the Tangential velocity, but i donīt have the tangential velocity in contour details--> Var Does anybody know how to sort out the problems? Thanks Rafael
July 19, 2006, 15:08 |
Re: Tecplot with fluent
in alter data equation
an there you have to specify your tangential velocity formula |
August 25, 2009, 07:15 |
hi frens
siva kumar
hey dudes,,,,
this is siva,,,,,,, i donno tecplot,,if u hav any tutorials plz send me,,,,,am working on combustion field,,,,,, plz send me if u hav any tutorials regarding tecplot,,,,,,,, my email is shshiva17@gmail.com |
February 21, 2010, 13:34 |
plot tangential velocity in Tecplot by export data from Fluent
Khairy
In my opinion the best way to do that is to export a tecplot data file from fluent directly as follow from file menu select export then select tecplot from the most right panel select the variables you want to plot say tangential velocity axial velocity ... and from the surface panel select the surfaces say y0 (or any surface you already have, multiple selection is possible, every surface will be a zone in tecplot, if you did not select any surface the whole domain will be exported) then press export the generated file will be readable in tecplot as follow, file ==> load data file ==> tecplot dat file if you select some surfaces select 2D (or xy if you exported lines from fluent) while if you did not select 3D also you can make slices to plot at certain plane or lines inside Tecplot i hope these useful, for more details check the Fluent and Tecplot manuals. Regards, Khairy |
February 25, 2010, 10:47 |
hey,
my Problem is to get graphics of cas. and dat. files in my powerpoint presentation. How can I do that? Thanks in advance. Best regards, Dominic |
October 28, 2010, 14:51 |
Go to file export here by default is WMF select bmp, jpeg or Tiff whatever you want and there you go!!!!!!!
August 23, 2012, 11:31 |
sa
Actually I am working with Ansys Fluent and I am going to make plane in templet. I read what you guys wrote but I have problem with that. I went to file menu then sleeted EXPORT. But in export I could not find tecplot. The tecplot is in import. So would please give me some advice. The other question is that when I am using the other way to transport my model to tecplot, just the model got transported. I mean I could not see the velocity profile in my model ( because I am going to see the velocity profile in different positions (by making plane in the model). Would you please help me. |
February 9, 2018, 00:57 |
Regarding importing data from Fluent to Tecplot
Maharashtra
Rep Power: 8 |
Dear saharesobh
I am also facing same problem. Not able to import data |
Reading Additional Data Quantities from Fluent into Tecplot | fremder | Tecplot | 9 | December 16, 2016 15:35 |
how to read fluent Cl and Cd data in tecplot | lalit kumar | FLUENT | 0 | August 29, 2010 07:47 |
few quesions on ANSYS ICEMCFD and FLUENT | Prakash.Paudel | ANSYS | 0 | August 12, 2010 12:07 |
postprocessing Fluent Tecplot | unknown | FLUENT | 0 | October 11, 2009 06:34 |
Fidap to Fluent | Ravi | FLUENT | 3 | July 10, 2008 13:31 |
