Home > Forums > FLUENT
error!
Old   July 12, 2006, 10:47
Default error!
Rekha
Can anyone tell me what this error means in fluent 6.2??
Error: eval: unbound variable Error Object: porous?
How can I correct it?
Thanks
Old   July 12, 2006, 11:56
Default Re: error!
Seeker Phil
hi rekha,
Can you provide some more details about the error? It might help to get at the real problem.
From what I know, this is a numerical error with the solver. Being a little more technical, most variables that the solver uses are bound to some memory locations that holds the values used in the solution. For whatever reason, the solver can no longer associate the variable with a location.
Some things you might want to look out for: memory usage. Make sure your grid is within the memory of your computer.
Also, have you defined a porous condition and if so what settings have you used. Hope this is useful, Phil
Old   July 12, 2006, 13:40
Default Re: error!
Vivek
I assume u get this error while initializing. It is probably because of incorrect boundary conditons.
Thread Tools
Trackbacks are On
GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM 300 October 29, 2014 19:00
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 18:43
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
user defined function cfduser CFX 0 April 29, 2006 10:58
