July 13, 2006, 11:56 |
Oscillatory flow in a channel
Hello everybody,
I am trying now to solve a simplified thermoacoustic problem using Fluent6.1. It is simply an oscillatory flow problem inside a channel, The channel is: 1 m long and 0.08 m width with pressure inlet B.C.: p= 2000*cos(4*t)+patm and pressure outlet BC: p= -2000*cos(4*t)+patm initial conditions: p=-4000*x+patm (patm=1.01e5 pa) and zero velocity. time:0-->15.71s (period of one cycle is 1.571 s). properties of the fluid: kinematic viscosity=2.5e-4 m^2/s( so i am using a density of 1000 kg/m^3 and dynamic viscosity of 0.25 Pa.s) I used a udf to specify the inlet and outlet transient boundry conditions, and custom function for the initial pressure (because it varies with x). I am using the coupled solver, but i am getting a strange solution where the x-velocity is a function of y and x while it should be function of y only. The solution gives high velocity at the inlet and then it decreases. I suspect that there is a mistake in specifying the inlet condition, because even when i solve for steady state case, the velocity at the inlet is high and then it becomes almost constant and function of y only. Is there any suggestion. Your help is so much appreciated. Best regards, YMS |
Channel flow setup in Large-eddy simulation | Weihua | Main CFD Forum | 6 | November 17, 2015 09:33 |
Help on laminar oscillatory channel flow [Help needed - Urgent] | Dtkcby | Main CFD Forum | 0 | March 19, 2011 15:11 |
Yacht in Open Channel Flow | andreimour | FLUENT | 1 | October 14, 2010 23:54 |
Flow within a thin channel | al0Vera | FLUENT | 0 | June 15, 2009 10:20 |
Slug flow in square channel | PaulC | FLUENT | 0 | December 5, 2005 02:03 |
