July 14, 2006, 03:45 |
Free Surface Jet Impingement
Hi
I am modelling Jet impingement onto a flat plate, but I am having difficulty establishing the correct boundary conditions. I have created a 2D VOF axi-symmetric model, with air as the primary phase and oil as the secondary phase, pressure inlet and pressure outlet. I initialise and then patch oil (Volume fraction 1) into the required region then run the itteration using a time step of 1E-8 (other wise floating point error occurs). After a short while i display the contour plot, but it appears as though oil is entering through the outlet. I think I have made an error in defining the boundary conditions/patching in the oil. can anyone provide any help with this matter? Thank you in advance John |
Display Modes | |
free surface display | carno | Siemens | 4 | October 7, 2005 01:03 |
free surface display | novice | Siemens | 5 | August 4, 2004 01:07 |
Equilibrium of a free surface under surface tensio | Ryan | Main CFD Forum | 1 | August 7, 2001 16:14 |
Velocity on Free Surface Boundary | Lin F.F | Main CFD Forum | 3 | August 4, 2001 11:30 |
Modeling Free Surface Flows | Elliot Schwartz | Main CFD Forum | 5 | August 25, 1998 21:03 |
