Home > Forums > FLUENT
Residence time calculation
Old   July 17, 2006, 15:09
Default Residence time calculation
Vidya
Hi all,
How do I get the residence times in Fluent? I'm not injecting any particls per se into the flow. I just want to know how long the fluid remains inisde my geometry and for how long they stay in each zone.
Thanks.
Old   July 18, 2006, 05:14
Default Re: Residence time calculation
Thomas
display->path lines-> coloured by residence time
thomas
Old   July 18, 2006, 08:22
Vidya
Hi Thomas,
I didn't find the residence time option in the COLORED BY menu.
Where can I find it?
Thanks.
Old   July 19, 2006, 16:25
J.Gimbun
Try step by step in particle tracking, I believe this could give you the residence time. Also see whether it is one way or two way coupling, it will give slight difference in result. Good luck.
Old   July 21, 2006, 19:34
Vidya
The particle tracking panel has the option for plotting/ writing to file the residence time values, but somehow I'm unable to activate the DISPLAY or WRITE buttons. It's always gray (inactive), no matter what I tried. How do I activate this?
As I said before, I do not have any injected particles in my flow stream.
Thanks.
Old   August 8, 2006, 08:27
Alex
The Display button of the Particle Tracks window will not work until you have selected a Injection in the "Release from Injections" - box( which is only possible if you have configured at least one injection. And you need some Iterations as well to see anithing) Hope, this helps a little,
Alex
Thread Tools
Trackbacks are On
Full pipe 3D using icoFoam cyberbrain OpenFOAM 4 March 16, 2011 10:20
help in residence time calculation hoolei FLUENT 0 November 8, 2010 01:10
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
AMG versus ICCG msrinath80 OpenFOAM Running, Solving & CFD 2 November 7, 2006 16:15
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
