Load UDF's
Old   July 18, 2006, 06:03
Default Load UDF's
Albert Franco
Hello, I've tryed to load the udf files of the oficial tutorials, and I couldn't achieve it. I can build the udf but when I try to load it an error message appears. Can anyone help me? (I'm a begginer))
Old   July 18, 2006, 07:36
Default Re: Load UDF's
saghir
hello, write me the error message or log file
Old   July 18, 2006, 07:49
Albert Franco
The error message says that the system can't find the file (see below) but I don't understant why because both files are in the same folder. I can buil but I can't load. Thank you for your time, I'm a beginer, I'm doing the tutfiles in order to learn basics skills of CDF.
Opening library "lib_drag"... Error: open_udf_library: The system cannot find the file specified.
Error Object: ()
Old   July 18, 2006, 08:45
Fabrice
What sort of UDF is it (which macro is in the file: DEFINE_PROFILE(),CG_MOTION(),.... ??
Do you try to interprete or compile the function?? To compile the function you need a C compiler installed on your computer such as Visual C++.
Fab.
Old   July 18, 2006, 10:06
greg
Fabrice is right. I had the same problem (or similiar). You need to check what kind (or which) compiler is good for your operating system. A list of all compilers is on
www.fluentusers.com Make sure to install well a compiler. U can find a instalation steps on fluentusers website.
Old   July 18, 2006, 10:48
Albert Franco
I don't know if this is what are you asking for... I've opened de .c file and the sentence with DEFINE that appears is
DEFINE_EXCHANGE_PROPERTY(custom_drag_syam, cell, mix_thread, s_col, f_col)
Actually it isn't a particular problem with this UDF's, my real problem is that I don't know How to open/compile any UDF file.
I was trying to compile the function, not to interpret. If it can help you I was doing the tutorial called "Modeling Uniform Fluidization in 2D Fluidized Bed" that is in the following link: http://www.learningcfd.com/login/flu...ials/index.htm
As I've said before I think that it isn't a particular problem with this udf. I've read the manual and now I'm "playing" with dev C++ in case I got the solution.
THANK YOU for helping me!!!
Albert
Old   July 19, 2006, 15:42
Le
Hi Man, You should remember that there is only MICROSOFT VISUAL C++ that is compatible with compiling in Fluent. I think that DEV C++ is not compatible with Fluent. For this reason, you could not compiled the file and get the error. So if you are using Dev C++, you should install Mic visual C++ and do it again.
Old   July 20, 2006, 02:44
Albert Franco
Okas thank you!!! I'll try it.
problem using property udfs in parallel mode EllenW Fluent UDF and Scheme Programming 5 July 10, 2009 04:31
problem using property udfs in parallel mode EllenW FLUENT 0 June 23, 2009 17:18
Unsteady and Flux UDFs for UDSs tom FLUENT 0 February 13, 2009 10:27
Using load vector for parallel partitioning Kevala FLUENT 0 May 1, 2001 12:11
Experimental Repository for UDFs, Journal Files and Scheme Scripts Jonas Larsson FLUENT 0 March 5, 2000 15:36
