Gambit Meshing complex geometry
Old   July 12, 2006, 14:10
Default Gambit Meshing complex geometry
Edwin
Hi guys. Having a big problem here. Im trying to mesh a highly complicated 3D geometry of a dam. My computer hangs before it even begins to start the meshing. The sources are incorrect. What do you suggest i choose for sources and how do i make it fast. Further, what meshing scheme should i use?
Old   July 14, 2006, 02:08
Default Re: Gambit Meshing complex geometry
ztdep
I think your computer hangs, because the quanlity of the mesh is too large! did you use the unstructed grid system! i strongly suggest you use a multiblock structed grid !
regards
Old   July 19, 2006, 15:02
cip
hy
my idee is to create small volumes linked togheter and to mesh them one at the time. the best is to realise a structured mesh. it takes time and you have to have imagination. normaly with an unstructured scheme it cames fester. try to cut your domains in slices.
b regards cip
[GAMBIT] meshing in GAMBIT, a flow through a pipe having complex inflow geometry mazhar1613 ANSYS Meshing & Geometry 1 January 11, 2012 23:18
Error meshing a helicopter rotor with Gambit Stefano FLUENT 3 June 9, 2010 08:31
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 08:17
Question: Geometry file for Gambit yueke FLUENT 0 May 28, 2009 09:55
GAMBIT meshing problem Gauthier Lambert Main CFD Forum 1 August 3, 2000 09:22
