July 20, 2006, 06:39 |
fluent error while iterating
Hi!
while iterating a 3d inkompressible sim, the continuity residual is increasing almost like linear... After about 200 iterations (continuity residual is at 10^3) Fluent gives following error: Error: cx-xy-append-data: invalid number (y) Error Object: nan What happend? Ralf |
July 20, 2006, 13:47 |
Re: fluent error while iterating
It is more than sure that you have a setup error in your model. Something like setting unphysically large or small values for boundary conditions parameters, etc. To be able to pinpoint the error I must know exactly what are you simulating and the complete setup of your model. The "nan" message translates into an error that propagates into the equations and it is so large that the numerical alghoritm is not able to dump it, so it grows to infinnity...
Razvan |
July 21, 2006, 02:11 |
Hi!
Thanks for your answer! My model: It is 3D, flow inside a square chanel with 60 cylinders parallel to the flow. Perpendicular to the cylinder is a grid (supporting the cylinders), that is modeled as porous zone. The medium is air at 20°C and atmospheric pressure. The simulation is isotherm and incompressible (in futur, the cylinder are hot and the flow is cooling them). Flow is turbulent with k-e and std. wall functions. The geometry is symmetric, so I have 2 walls and 2 symmetrie planes. The inlet is contant mass flow, outlet is pressure outlet. The grid is made from ab. 500.000 tet cells with hex core. Solver is seggregated. Now, when I turn to coupled solver, the simulation is working, but very slow... also x- and z-vel. residuals are to high (between 1 and 5). But the results seem to be not wrong: right direction of mass flow, wall bc is ok. So, what do you suggest?? Ther might be something wrong with the grid... the grid check failed and there is now possibility to smooth the grid... maybe thats the error!! Any ideas?? Ralf |
July 21, 2006, 02:20 |
If the grid check really failed, then this could be the problem. Which exactly is the step of the grid checking sequence where it failes (I mean skewness, number of nodes, handedness, etc)?
Razvan |
July 21, 2006, 05:53 |
Grid Check
Domain Extents: x-coordinate: min (m) = -3.300000e-01, max (m) = 0.000000e+00 y-coordinate: min (m) = 6.400000e-01, max (m) = 1.700000e+00 z-coordinate: min (m) = -5.250000e-01, max (m) = 0.000000e+00 Volume statistics: minimum volume (m3): 2.995679e-10 maximum volume (m3): 2.407841e-05 total volume (m3): 1.384525e-01 Face area statistics: minimum face area (m2): 5.551780e-07 maximum face area (m2): 8.920985e-04 Checking number of nodes per cell. Checking number of faces per cell. Checking thread pointers. Checking number of cells per face. Checking face cells. Checking bridge faces. Checking right-handed cells. Checking face handedness. Zone 26: 774900 right-handed, 10 left-handed Checking element type consistency. Checking boundary types: Checking face pairs. Checking periodic boundaries. Checking node count. Checking nosolve cell count. Checking nosolve face count. Checking face children. Checking cell children. Checking storage. Done. WARNING: Grid check failed. |
July 21, 2006, 06:04 |
That's clear. There is nothing you can do about this one. You have to start all over again and build a new mesh. If you can send me the .dbs file, maybe I can give yo some advice about that...
Razvan |
July 21, 2006, 06:25 |
ok... but it is about 150 MB, thats too large for email...
I will try, to put it on our server. But unfortunately thats not possible until monday (admin already at home Thanks a lot for help Ralf |
July 21, 2006, 06:33 |
I meant only the geometry, without the mesh. That should be small enough (no more than a few megabytes), especially if you use an archiver like WinRAR which could reduce the size of the .dbs file up to 5-6 times!
Razvan |
July 21, 2006, 08:38 |
#9 |
look for repair-face-handednes in grid menu in textual user interface. This could help
reg, pp |
July 21, 2006, 09:17 |
#10 |
Hi!
first: the .dbs file is about 150 MB, maybe there is the error... second: I can not find the "repair-face-handednes" function in fluent. There is no repair option in the text menue (Fluent 6.2.16) Thanks for help! Ralf |
Stopping a Fluent batch job AND saving the data! Possible? | Volker Pawlik | FLUENT | 13 | December 28, 2020 04:16 |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 03:22 |
Fluent 6.3 32bit vs Fluent 12.0 64bit | ibex7 | FLUENT | 7 | April 18, 2011 02:44 |
Compared MRFSimpleFoam and Fluent in a centrifugal pump! | renyun0511 | OpenFOAM Running, Solving & CFD | 8 | July 6, 2010 06:24 |
Fluent 12.0 is worst then Fluent 6.2 | herntan | FLUENT | 5 | December 14, 2009 02:57 |
