Concentration dependent surface tension
Old   July 25, 2006, 13:47
Default Concentration dependent surface tension
ling
I am using a VOF model, with a free surface of water and air. A chemical species is floating on top of the water and is changing the surface tension of it at the interface.
I would like therefore, to write a UDF of surface tension cofficient that is dependent on the chemical species concentration, under the multiphase, "interaction" option.
I am also using the DEFINE_PROPERTY udf. But the problem is ... what should I put for the thread in the C_YI(c,?,species_index) ? it is at the interface, so, which is it ? the air, the water or the mixture ?
I tried several sub or super thread options but none worked.
Any advices ? Thanks in advance !!
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
continuum surface tension model yukn Main CFD Forum 0 October 8, 2011 06:43
surface tension output tom FLUENT 1 November 19, 2010 09:09
Surface tension problem. Kes FLUENT 0 May 19, 2008 22:49
surface tension gradient on a free surface Abrem FLUENT 1 April 30, 2006 03:41
