CFD Online URL
Home > Forums > FLUENT
Help on solidification and melting
Like Tree1Likes
  • 1 Post By Lim
Old   July 23, 2006, 06:18
Default Help on solidification and melting
Lim
Hi all, I have an enclosure spherical glass that is contain with phase change material (PCM) that is in its solid state initially. Heat will be applied above the melting temperature of the PCM around the spherical glass. During the melting process of the PCM there will be 2 phases present in the enclosure, the liquid and solid state. The solid PCM will drop to the bottom due to the gravitation force.
A 2d mesh was created and exported out from Gambit.
In Fluent, I used Solidification and Melting function in my simulation. All Material properties of the PCM and glass have set accordingly. The Gravity was also enable with Y=-9.81 in the Operating Condition and the Variable-Density Parameters was also set to an operating density of PCM, that is 777kg/m^3. The Body force weighted under Discretization in Solution Control was also selected.
After iterating for 200 sec, the values for the Liquid fraction was calculated but the simulation did not show the solid PCM sink to the bottom of the enclosure.
How can I make the solid PCM to sink to the bottom as it melts?
Thanks, Lim
alighanei likes this.
Old   September 20, 2010, 02:00
Default spherical enclosure
chriss's Avatar
Christiano Santim
chriss is on a distinguished road
I have the same problem sometimes.
C Santim
Chemical engineer
chrisoff22@yahoo.com.br
chriss is offline   Reply With Quote
Old   December 1, 2010, 05:03
wanglitian is on a distinguished road
You can not get the result that the solid phase sink to the bottom. Because the Solidification Model in Fluent introduces an assumption that the solid phase is fixed and can not flow with the liquid phase. In my opinion, maybe you can try to use the VOF model. But the phase change between liquid and solid interface may be new problem you need to solve.
wanglitian is offline   Reply With Quote
Old   May 17, 2011, 07:51
bitak
bitak is on a distinguished road
hi.
I think for simulation of melting of spherical body, we should use slurry model (pcm-granular euilerian model) in fluent.
but I don't know the result is true or no!
bitak is offline   Reply With Quote
Old   June 3, 2011, 12:41
skullCFD is on a distinguished road
I believe Fluent solves only constrained melting/solidification. The problem you are trying to solve is unconstrained melting, which is different and needs an additional momentum equation for the solid phase. The gravity vector you enabled is only for the Boussinesq term but not for the solid to sink.
skullCFD is offline   Reply With Quote
Old   May 2, 2014, 19:58
Default 3D solidification
minarhn is on a distinguished road
I am working on a phase change process including natural convection in closed domain. as long as I am dealing with a 2D model, I get reasonable results. but when I switch to a 3D model, I don't have any movement in the interface which means that it doesn't solve the solidification/melting!
Do have any suggestion or comments about this?
Thanks
minarhn is offline   Reply With Quote
Thread Tools
Trackbacks are On
solidification and melting slek Fluent UDF and Scheme Programming 2 November 30, 2011 12:13
solidification and melting mojtaba-azadi FLUENT 2 November 30, 2011 11:27
melting or solidification model in CFX jasonchang CFX 2 July 22, 2011 09:24
Solidification & Melting Curves CFDtoy Main CFD Forum 0 December 18, 2008 15:58
Solidification and melting with CFX Don CFX 0 December 1, 2008 12:30
