non uniform velocity profile at inlet
Like Tree1Likes
  • 1 Post By Ralf Schmidt
Old   July 22, 2006, 15:26
Default non uniform velocity profile at inlet
hiba
hello,
is it possible to define a non uniform velocity profile as a boundary condition at a velocity inlet; that is, can i set the velocity profile at the inlet to be parabolic, for example, instead of constant? if yes, how?
thank you
Old   July 23, 2006, 00:08
Default Re: non uniform velocity profile at inlet
Le
It is very easy. Please read the UDF manual file, you will know how to do. I remember that there is a example like what you want to do.
Old   July 25, 2006, 03:32
Ralf Schmidt
Hi!
There is another way:
write the profile as a table (x,y,vx,vz,vy or something like that) or take it from another simulation (with write profile).
Than, import the profile (file->read->profile) and use the vel. components as vel. components in the velocity inlet BC.
You may orientate the profile, look in the fluent manual, how that works.
Ralf
Abhi.shek likes this.
UDF inlet velocity profile mismatch with Fluent ChristineL Fluent UDF and Scheme Programming 15 November 25, 2016 06:45
inlet velocity profile for fully developed turbule pankaj saha Main CFD Forum 4 August 24, 2007 16:53
using profile to specify inlet VOF and velocity yf FLUENT 8 June 2, 2005 05:40
inlet velocity profile in Polyflow srinu Main CFD Forum 0 January 16, 2003 20:27
inlet velocity profile in Polyflow srinu FLUENT 0 January 16, 2003 20:25
