journal file command for writing mass flow rate
Old   July 26, 2006, 10:51
Default journal file command for writing mass flow rate
James
Hi All,
I need the command you will use for writing the mass flow rate at a specified plane using a journal file.I am able to do it manually using Solve>Monitors>Surface ....
But i want to be able to do it using a journal file. For writing pressure on a surface located at a plane x=-146, i use the following lines of command in a journal file:
/solve/monitors/surface/set-monitor monp-01 pressure plane-x=-146
n n y /.auto/rz+cluster+w0/work/jw656314/RANS/urans_edm/plane_data/monp-plane-x=-146.data y "Area-Weighted Average"
I want similar lines of command for writing the mass flow rate at a surface. Specifically, i want to record the mass flow rate a the air inlet and the fuel inlet.
Any suggestions will be appreciated.
James
Mass flow rate through each cell Babakjingo Main CFD Forum 0 August 21, 2011 03:18
Mass flow rate sepidecent CFX 0 August 9, 2011 00:15
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 BlGene OpenFOAM Meshing & Mesh Conversion 10 August 6, 2009 04:26
Mass flow rate Neser CFX 4 February 14, 2004 00:27
