Jay Shim
July 27, 2006 04:03 |
Gambit Startup Window
Hello, everyone. I'm having trouble with the Gambit startup window. Actually, I want to use the gambit as a batch process (using the journal file), and after the gambit run, the control does not come back to command prompt due to this Gambit startup window (small window which you get when you first launches the gambit by GUI). As a result, I cannot process the next batch job automatically. (I always need to click the "close" button manually on this window) Does anyone know how to setup the gambit so that this startup window does not appear?
