wall & wall shadow net heat flux
Old   July 28, 2006, 10:42
Default wall & wall shadow net heat flux
Barbaros
I have a simple 2-D geometry. On top of a wall there is a channel flow. There is heat flux coming into the wall. It looks like the following:
<--- fluid zone <---
| solid zone |
Fluent creates a shadow wall at the interface. I meshed the solid zone also to see the conduction. When I look at the heat flux at the interface wall and its shadow they are not the same. Even if I run more iterations it fluctuates around some number. For example for solid side it's -24W and for fluid side it's 20W. In terms of signs this makes sense; fluid is beig heated by the wall. But why there is such a difference? What is happening to the 4W?
Old   August 5, 2006, 02:00
Default Re: wall & wall shadow net heat flux
bingbing
I have a same question,too. I gave the heat flux ratio of the bottom of solid zone.When I look at the temperature at the interface wall and its shadow they are not the same.For example for solid side it's -330K and for fluid side it's 340K.If I meshed the fluid zone with more grid cells,the temperature of the wall approaches to 340K.
So I suggest that you can mesh the boundary layer near the wall in the fluid zone.
my english is so poor!(yumen!)
Looking for a code of exact wall heat flux on cylinder enclosure wall ljwbuaa Main CFD Forum 5 January 16, 2011 08:33
Heat flux at the wall. Sang FLUENT 0 February 19, 2010 23:20
calculation of wall heat flux in CHT richard CFX 1 July 23, 2009 09:00
how to export "wall heat flux" to tecplot? victor CFX 3 November 27, 2008 09:45
Basic question: UDF for wall heat flux Carl FLUENT 1 August 5, 2006 19:01
