Mesh in Gambit/Fluent
Old   June 24, 2006, 05:43
Default Mesh in Gambit/Fluent
Mark
Hi to everybody! I know that Gambit can mesh .igs files . (I'm realizing a project I will save in .igs ) The mesh generated by Gambit (e.g. saved in .msh format) can be used in Fluent and other programs similar to Fluent. I need to have only the mesh file (.msh without inlet/outlet conditions) outputted by Gambit... but I use Gambit very little and I'm not able to solve some problems given by Gambit about 2 surfraces... So.. I'm looking for someone who could make the gambit meshes for me.. I think it will be very quick to do for anybody who use Gambit everyday...
Old   June 25, 2006, 06:23
Default Re: Mesh in Gambit/Fluent
sam
sure . send me ur files .
i will certaily help u
ragard sam
Old   June 26, 2006, 03:33
Durgendra
u can send me ur .igs files. I'll try it
Old   June 27, 2006, 05:20
Mark
Wonderful!!!!! At this moment I'm away from my house(and my PC) because of work.. I'll be back tomorrow (28th of June) and I'll send you the critical .igs !!! Thanks!!!!!!!!!! Have a nice day!
Old   June 27, 2006, 05:23
Mark
Great!!!!! Now I'm away for work, but I'll be back tomorrow (28th of June) and I'll send you the critical .igs !!! Thanks!!!!!!!!!! Regards!
Old   June 28, 2006, 07:49
Mark
Hi Sam! I'm sending you a link where you can download a .zip file called Meshing-Problems.zip !
Available links: http://www.megaupload.com/?d=0ZKWO70A http://www.megaupload.com/it/?d=0ZKWO70A
You only have to go in the upper-right of the page (near MEGAUPLOADS writing), insert tre shown letters and wait 45 seconds in order to download the .zip !
In the .zip you find two .igs files: - Assembly_(Threaded).igs - Problematic-Component_(Enlarged).igs
Great if you will mesh the assembly! But Corpo.igs colud be sufficient for my puropse!
They aren't the final version of my project.. if you succeed in meshing, can you also mesh the final .igs version (when I complete it)?
If you can't download them, please send your email address to me at markchat5@libero.it and I'll send you everything!
Thankx a lot!!!!!!!!!!!!!!
Old   June 28, 2006, 07:50
Mark
Hi Durgendra! I'm sending you a link where you can download a .zip file called Meshing-Problems.zip !
Old   July 9, 2006, 02:00
behnam
Hi i need a steam reforming reactor mesh for fluent with catalyst particle
Old   July 19, 2006, 16:37
J.Gimbun
You can draw & mesh the reactor, then either patch the catalyst partice loading like in fluidised bed if I'm right.
Old   July 29, 2006, 09:43
behnam
i need a mesh of fixed bed reactor with catalyst partice for steam reforming conversion. thank you.
Old   July 29, 2006, 16:19
  #11
J.Gimbun
I'm not doing a fluidised bed or packed bed simulation. Anyway, I suppose you can do it by adding a reaction (via species modelling) on fluidised bed case. Another idea might be by assuming the bed as a porous media. The second idea shouldn't be accurate but it does simplify your problem (maybe). Fluidised bed tutorial is available in Fluent user or in Fluent help. Good luck.
[ICEM] Negative volume error in hybrid mesh siw ANSYS Meshing & Geometry 4 September 3, 2014 05:25
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
[snappyHexMesh] non-smooth mesh Svensson OpenFOAM Meshing & Mesh Conversion 11 January 18, 2012 09:13
2d irregular grid Remy Main CFD Forum 1 December 22, 2008 04:49
