transient mass diffusion
Old   August 2, 2006, 15:51
Default transient mass diffusion
brian
I'm having trouble modeling the following: A vertical pipe is separted with a valve in the middle. Above the valve is fluid-1, below is fluid-2. I want to model the diffusion/mixing; both conc gradient driven, and gravity driven. How would I do this? When I use the species model I can't figure out to specify the zone composition just at the beginning. Right now I specify one zone as a fixed value of pure fluid and see how it diffuses into the other zone. Is there a way to just specify at time=0, and model what happens? Thanks
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
UDF for transient pressure inlet, mass flow check at nozzle exit and volumetric heat kokoory FLUENT 0 August 17, 2011 02:07
Star-CD transient simulation, problem of loss of mass kit STAR-CD 3 April 13, 2010 11:34
Mass Diffusion: Transient and Steady State BC rval CFX 3 November 19, 2008 00:52
