-   -   Journal file for for NITA scheme using LES (http://www.cfd-online.com/Forums/fluent/41916-journal-file-nita-scheme-using-les.html)
anindya August 2, 2006 13:29
Could someone please let me know the lines to put in a journal file when using the NITA scheme. I have used journal files for the unsteady schemes using the commands as shown below.
/solve/set/time-step 0.0001 /solve/dual-time-iterate 1000 10
Thanks
Anindya
thomas August 2, 2006 23:48
Re: Journal file for for NITA scheme using LES
try this ---------------------------- solve set time-step 0.0001 dual-time-iterate 1000 ----------------------------
- not sure what your 10 refer to ? - dont forget to do regularly auto-save
anindya August 3, 2006 02:25
Actually that 10 was for the ITA scheme where we have to specify the number of iterations per time step.
I am confused about the NITA scheme as it does not require the inner iterations.
Thanks for the suggestion. Will try and see.
Anindya
thomas August 3, 2006 07:38
NITA is a non iterative, so you dont need it try it !
Anindya August 6, 2006 01:10
Its working. Thanks thomas. Anindya
thomas August 6, 2006 11:54
good for you !
