-   -   case about laminar flow past a surface-mounted rib (http://www.cfd-online.com/Forums/fluent/41964-case-about-laminar-flow-past-surface-mounted-rib.html)
Baicang Liu August 8, 2006 07:20
Hello,I am conducting a calculation using FAM(Finite Analytic Method),the calculated problem is laminar flow past a surface-mounted rib with Re=800, does anybody know about a benchmark solution of the mentioned problem using Fluent or other method? So I can make a comparison and check out my calculated results. Any help is appreciated. Thanks in advance! Sincerely, Liu
