August 15, 2006, 04:20 |
rotating disk
Hello, I'm simulating a rotating disk in the air but my simulation doesn't correspond to the experimental measurements. I've already meshed the disk and the control volume, and the mesh quality is about 0.3 and there aren't bad cells. Within this velocity, the temperature around the disk is about 100°C by experiment but during my simulation the temperature is only at 50°C. The aim of this simulation is to determine the moment at the axis. Now, I try to change the fluid (air) into ideal gas and change the options for the density and viscosity.
Could someone give me some advice about really important parameter ? What is really the consequence of the turbulent viscosity option in fluent? Disk specification: Radius 95 mm; thickness 2 mm; roughness 5 micrometer, frequency 0-500 Hz Model: k-epsilon RNG; coupled; energy Best regards David |
August 15, 2006, 09:02 |
Re: rotating disk
bonjour,
je répondrai bien volontiers à votre annonce mais malheureusement je ne parle que français ou allemand? |
August 15, 2006, 09:15 |
Re: rotating disk
your are very bad with fluent..... try to change job !
August 15, 2006, 09:40 |
Re: rotating disk
ok, i'm looking for an another job.
August 16, 2006, 06:05 |
Re: rotating disk
I think that fluent is a powerful soft.... damage that it's difficult to use it. there are some people very good and some also very bad . Dammage for you !
you can go to bed. |
August 16, 2006, 06:07 |
Re: rotating disk
help help help me please !
do not play with me..... i am Calimero |
rotating disk symmetric grid, help please | bene | FLUENT | 0 | November 5, 2010 07:09 |
vof rotating disk 2d | bene | FLUENT | 1 | October 24, 2010 13:18 |
Rotating Disk | MohsenZendehbad | FLUENT | 2 | July 13, 2008 13:43 |
Numerical solution to the rotating disk problem? | johny | Main CFD Forum | 7 | September 5, 2005 05:53 |
liquid on a rotating disk? | Cehuang | FLUENT | 0 | March 10, 2001 06:23 |
