-   FLUENT (
-   -   to reset iteration number in FLUENT (
Mohan R August 15, 2006 04:14
If u are fed up of the large iteration numbers. (this happens generally when parameter sensitivity of the same case file is set and iterated further.....)
Try this ...
Step1. Read Case/Data file for which the iteration number can be restarted
Step2. save data of all variables in the domain using INTERPOLATION. (File> Interpolate) For Eg. "xyz.ip"
Step3. Initialize the same case (Solve> Initialize> Int)so the iteration counter is set to 0
Step4. read the interpolated file (File> Interpolate> Read and Interpolate) for eg. "xyz.ip"
Step5. Start iterating !
Iterations number will start from 1, and also the output fles will be store with the same iteration number.
cadaei August 15, 2006 08:17
Re: to reset iteration number in FLUENT
or just type solve/montiors/residual/reset/yes in the TUI!
Mohan R August 16, 2006 01:30
Sorry cadaei, ur method will just show the reset in iteration number, but if u see the contors, or write the history files u will get have the old iteration number.
SJSW June 18, 2014 01:16
Dear Mohan R,
is there any additional software that needs to be installed before I try this method?
Thank you.
