August 23, 2006, 20:24 |
Problem in Reporting Unsteady Particle Fates
Hi Everyone,
I am having trouble to get FLUENT to report the particle deposition position under unsteady condition for both flow and particle phase. What I am simulating is particle deposition in a sudden contracted pipe with sin waveform airflow. I can get FLUENT to report the particle deposition position under steady condition (assume constant flow) using REPORT -> DISCRETE PHASE -> SAMPLE -> select boundaries (ie. pipe_wall) and Release from: injection-0 -> click COMPUTE, then FLUENT will create a pipe_wall.dpm file which contains the particle deposition position. This method has been documented in FLUENT manual. However, the method from the manual for unsteady reporting doesn't work on my case, where I did click START in Sample Trajectories panel, then Fluent created the file (.dpm) but contains nothing inside the file after I click STOP. So, I am wondering if anyone here can kindly tell me what is wrong with my method. Thank you very much in advance! Cheers, Nelson |
how to compare unsteady state problem results from FLUENT with Experimental data? | cuddaloreselvam | FLUENT | 0 | July 10, 2011 08:25 |
Using sliding mesh for unsteady turbomachinery problem | happyman | Main CFD Forum | 3 | July 8, 2011 14:29 |
Using sliding mesh for 3D unsteady turbomachinery problem | happyman | FLUENT | 0 | June 22, 2011 15:54 |
particle problem | Andy Chen | FLOW-3D | 2 | January 11, 2010 02:30 |
Question concerning about unsteady problem.... | ghlee | Main CFD Forum | 6 | October 2, 1998 05:36 |
