December 19, 2012, 17:18 |
point determination
kris pani
Rep Power: 14 |
Does anybody know if Fluent is able to determine a specific point, for example, I have a cylinder as a model and I'm wondering if Fluent can find the point which has the lowest temperature in a heat transfer problem, and give me the coordinates.. Thank you, K.P |
December 20, 2012, 00:52 |
Lucky
Rep Power: 65 |
I don't think so.
December 20, 2012, 14:52 |
kris pani
Rep Power: 14 |
Thank you..both !!
December 23, 2012, 05:42 |
kris pani
Rep Power: 14 |
Goodmorning Sixkillers
I read the DEFINE_ON_DEMAND in UDF guide and I used the example.. Unfortunatelly I am not familiar with C language, so for that example, I can only take the min and max of temperature and not the coordinates.. Am I doing it wrong or I have to do something more ?? Last edited by krisipanikou; December 23, 2012 at 11:41. Reason: quorte it by mistake |
December 23, 2012, 11:32 |
#6 | |
kris pani
Rep Power: 14 |
I read the DEFINE_ON_DEMAND in UDF guide and I used the example.. Unfortunatelly I am not familiar with C language, so for that example, I can only take the min and max of temperature and not the coordinates.. Am I doing it wrong or I have to do something more ?? |
December 26, 2012, 03:59 |
Rep Power: 14 |
You can use macro C_CENTROID to obtain centroid of each cell. Basically you need to iterate through all cells in your domain and save location (centroid) of a cell with min/max temperature and then print its location.
cylinder, point determination, specific point |
problem in toposet | Ahmed Khattab | OpenFOAM Pre-Processing | 27 | March 3, 2023 21:12 |
[blockMesh] error EOF in blockMesh | Ahmed Khattab | OpenFOAM Meshing & Mesh Conversion | 7 | May 17, 2012 00:37 |
block-structured mesh for t-junction | Robert@cfd | ANSYS Meshing & Geometry | 20 | November 11, 2011 04:59 |
[Gmsh] Gmsh and samplesurface | touf | OpenFOAM Meshing & Mesh Conversion | 2 | December 10, 2007 02:27 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
