transient simulation of mixing tank
Old   August 27, 2006, 23:55
Default transient simulation of mixing tank
Haresh Patel
Hi
I am simulating a mixing tank with 300 RPM.In my model we have two misible species are assumed completely separate at starting i.e. toluene in top layer and styrene in bottom layer at the start in the tank.I want to know what should be ideal time step. With time less then 0.1 sec computational time is too high. If i take 1 sec time step then scaled residual is not folling below 10-3 for continuity.
Can u suggest about judging convergence? Should i consider monitoring other parameter and should i ignore residual?
will parallel processsing be useful for transient simulation? I have 97000 cells in my geometry?
3D mixing tank using MRF/SRF cfd_confuse Main CFD Forum 1 September 13, 2016 02:43
Simple Water Tank Transient 88phil88 CFX 5 March 17, 2014 03:48
Beginning a Transient Simulation Norflow CFX 2 October 7, 2011 00:38
3D mixing tank using MRF/SRF cfd_confuse FLUENT 0 October 2, 2010 03:46
Mass conservation problem in mixing tank multiphase simulation rockewan FLUENT 0 April 6, 2010 12:34
